corpsy600r Posted March 26, 2010 the bike came with a headlight and tail light,can i just add a switch and use the power from the head and tail light Share this post Link to post Share on other sites
asf Posted March 26, 2010 Does it have a voltage regulator or battery? The output from the stator should wire through a regulator of some sort then to your headlight. You can run a switch to the headlight but the tail light should be on all the time so no need to wire in a switch there. You should be able to run the same power output to both. Check your PM Share this post Link to post Share on other sites
creeky Posted March 26, 2010 You will need a regulator/rectifier for DC power and a battery for ballast. Share this post Link to post Share on other sites
corpsy600r Posted March 26, 2010 ok can i add signals and use the power that goes to the headlight will that damage anything Share this post Link to post Share on other sites
frisco Posted March 27, 2010 ok can i add signals and use the power that goes to the headlight will that damage anything It did not damage anything in my case - 95 xr600 no battery. Share this post Link to post Share on other sites
corpsy600r Posted March 27, 2010 thanks frisco that puts me a ease,have you added anything else like bigger headlight or any other dual sport hardware Share this post Link to post Share on other sites
frisco Posted March 28, 2010 - stock headlight - i hooked up the wires to the high beam only - this way you can turn the headlight off when you're offroad.... - stock taillight +stop light - front turn signals - ufo hand guards with blinkers built-in - rear turn signals - key ignition - replaced kill switch - it's was a must for me.... - 2 flashers - in the airbox - universal switch I guess that's it... Share this post Link to post Share on other sites
frisco Posted March 28, 2010 BTW headlight will dim a bit with blinkers on if you have a stock stator... If you plan t keep the bike for longer or add some goodies, a high output stator might be a good idea. Share this post Link to post Share on other sites
creeky Posted March 28, 2010 BTW headlight will dim a bit with blinkers on if you have a stock stator... If you plan t keep the bike for longer or add some goodies, a high output stator might be a good idea. If you add a 12V battery pack, this will eliminate the dimming of the lights problem. The battery pack will also allow use of a horn. Share this post Link to post Share on other sites
corpsy600r Posted March 28, 2010 so with all that does that make your bike road legal btw thanks for all the great info Share this post Link to post Share on other sites
