'90 XR250R Shock Valving Recommendation?
I have my shock apart to rebuild it with a blown seal, does anybody know where I can get a revalve stack shim chart to upgrade the valving before I reassemble?
The main Valve appears to be stock honda (it is black with small holes) even though the shock reservoir had a racetech sticker on it, so I was expecting a gold colored valve with larger holes like the RT GV pictures.
My specs are 1990 XR250R, 220lb rider, aggressive trail riding, currently have a 10.3kg/mm straight rate spring plus a "hot pink" progressive spring with no numbers on it.
Alternatively, does anybody have a used XR600 shock to sell that is a better to start with and a stack for that?
Many thanks
Here's a hint. Stock stack is:
Rebound:
30x.25x12 |x5
28x.25x12 |x1
27x.25x12 |x1
26x.25x12 |x1
25x.25x12 |x1
24x.25x12 |x1
22x.25x12 |x1
Compression:
34x.25x12 |x4
20x.25x12 |x1
34x.25x12 |x1
30x.25x12 |x1
28x.25x12 |x1
26x.25x12 |x1
24x.25x12 |x1
22x.25x12 |x1
21x.25x12 |x1
20x.25x12 |x1
Any insight on what to add?
