Sxc625
My bike has a HSR42 Mikuni. I need some help rebuilding the carb. The pin that holds the float in appears to be a press fit. Is there a special tool to remove this pin
If I remember correctly the float pin is lightly pressed into one side only, you have to figure out which it is so as to not have to push the whole pin thru the tight side. I think I used a small size (6mm?) 1/4 drive deep socket to back up the float pin perch and a small drift punch to drive it out. Shouldn't take much force.
1bd
