macadue Posted March 26, 2010 if i put a new pipe on my wr250 do i need to rejet it or will it still perform the same w the new pipe Share this post Link to post Share on other sites
KcDavis My Ride Posted March 26, 2010 Is it the same kind of pipe you had on before or a completely different pipe? You usually have to change the jetting up a little when you put different/after market pipes on. And most pipe manufacturers have recommended jetting. Share this post Link to post Share on other sites
macadue Posted March 26, 2010 i believe its a stock pipe on there now and i was thinking about putting a fmf fatty on it but idk if i should or not Share this post Link to post Share on other sites
haydenjsle Posted March 27, 2010 I run a FMF Fatty Gold pipe on my 97 WR250--when I was running the stock Mikuni VM carb, I stepped all the way up to a 410 main jet and down on my pilot to a 35. It pulled longer and harder on the top end and ran cleaner and crisper on the bottom end. Pipe aside--these bikes come jetted way lean on the main from the factory and a little rich on the pilot. Adjust your needle height and air screw as needed. Don't base your jetting on a new pipe--rather how it runs at your altitudes and conditions--use the factory jetting as a starting point. Share this post Link to post Share on other sites
