corsaman Posted March 26, 2010 hi , just rebuilding my pig and put the cam and chain on got it at tdc and the cam sprocket lines seem to be a little bit out, but i dont think its a full tooth on the sproket???👍 Share this post Link to post Share on other sites
brianhare My Ride Posted March 26, 2010 hi , just rebuilding my pig and put the cam and chain on got it at tdc and the cam sprocket lines seem to be a little bit out, but i dont think its a full tooth on the sproket???👍 That usually means that you have a stretched chain/worn sprockets,did you change the chain..?????????.....if it`s not lining up almost dead on it usually is the chain stretched...but not always...i`ve had 2 engines apart and both times the lines where perfect......a small amount out i wouldn`t worry over... B Share this post Link to post Share on other sites
