Suggestions on radiator guards
Putting IMS tank on 150 RB ,(Already asked on that fourm ,I guess I'm the first) W. C braces wont work.,, Any help ?
Thanks !
if your problem is theres no holes to go in where the screw holes are
maybe you could cut and bend a piece of aluminium to fit into the shroud screw hole
There are no holes on stock tank eather.. there's a horozontal brace that goes thru the bottom hole of the bracket to the other bracket (on the other side)the top hole has a short bracket that connects to the fwd. tank mounting bolt(which will no longer work).I'm thinking it wouldn't be good to attach it to the tank.I guess I should of asked How about FLATLANDS ?
I appericate the suggestion though !
