apadulo Posted March 28, 2010 Put a new clutch in and now it does not engage. When I pull in the clutch lever there is no resistance what so ever down by the cable!!! The little cable lever and the motor just turns freely! Could the two shafts not be alligned correctly??? thanks Share this post Link to post Share on other sites
brianhare My Ride Posted March 28, 2010 Put a new clutch in and now it does not engage. When I pull in the clutch lever there is no resistance what so ever down by the cable!!! The little cable lever and the motor just turns freely! Could the two shafts not be alligned correctly??? thanks Sounds like the lifter cup in the left cover is not engaging the long rod..this is a XRL???????..since i don`t know for sure........ I`d pull the cover off the clutch side,,and see if you can get the rod to retract correctly.. PUT YOUR MODEL IN YOUR SIG LINE..... B Share this post Link to post Share on other sites
