stremme12 Posted March 28, 2010 Basically I'm wanting a completely white rear number plates instead of the red part on top. Who makes those plates in completely white? Share this post Link to post Share on other sites
2fiftyryder Posted March 28, 2010 got mine from one industries Share this post Link to post Share on other sites
chopper61 Posted March 30, 2010 If you have an 04 or 05 you must order side panels and the rear fender for those years. The 06-09 items are completely different due to the change to the twin pipes on those models. If you want all white side panels they are available from UFO. Their white ones do not have the red at the top like the OEM Honda and Acerbis ones have. Share this post Link to post Share on other sites
WranglerV8 Posted April 2, 2010 I know this has been asked prolly several times,but not all models have dual exhaust,so why wouldn't they work? Share this post Link to post Share on other sites
chopper61 Posted April 3, 2010 I know this has been asked prolly several times,but not all models have dual exhaust,so why wouldn't they work? When Honda changed to the twin pipes the entire subframe and all of the items that mount to it were changed. The only mounting points that are the same between the 2 generations (04-05, 06-09) are where the subframe bolts to the main frame. Anything that bolts to the subframe must be of the same generation as that subframe including the plastic. Share this post Link to post Share on other sites
WranglerV8 Posted April 5, 2010 When Honda changed to the twin pipes the entire subframe and all of the items that mount to it were changed. The only mounting points that are the same between the 2 generations (04-05, 06-09) are where the subframe bolts to the main frame. Anything that bolts to the subframe must be of the same generation as that subframe including the plastic. That's the answer I've been looking for.All I've ever been told is that they won't work.No one has ever given a reason why and it seems b/c they did not know why.Thanks.👍 Share this post Link to post Share on other sites
