mrbenn Posted March 28, 2010 hi guys, anyone else had this problem? changes up fine but when i push the gear lever down...nothing there does seem to be some play on the shaft. any help greatly appreciated. Share this post Link to post Share on other sites
Noble Posted March 28, 2010 Remove the right side engine cover and clutch assembly and look at the gear sift index mechanism. The problem is in there someplace. Lateral play in the shaft up to 1mm or so is normal. Share this post Link to post Share on other sites
PBMW Posted March 28, 2010 Also on the left side of the motor, on the shift shaft there is a circlip. If it comes out of the groove, the shaft can mofe to the right and the pin in the shift mechansm becomes disengaged...So, check the circlip before opening it up. Share this post Link to post Share on other sites
mrbenn Posted March 29, 2010 thanks for pointing me in the right direction-turned out to be a small piece of something? wedged in one of those spring loaded bits that rotate the selector drum,gonna change the oil i think...cheers Share this post Link to post Share on other sites
