will not ingagae in gear
I have a friend dropping off a small yamaha quad so i can look at it i have never worked on quads befor but im willing to try for the guy, It's not engaging in gear, he says it's like there is nothing there does someone have an idea what it could be befor i crack it open.
if it is going in gear but won`t take off it might need a new clutch if it won`t go in gear at all make sure the shifter is not stipped somehow if that is goo make sure shifter shaft is not broke if that is good then it comes down to spliting the motor and checking all the gears but the gears might be good and it might need new shifter forks or shifter tumbler thows are inside the motor hope this helps
