No first gear?
Hey guys, looking for a little help, After a couple laps at my local track, I stalled my bike after a jump, then when I kicked it to start it I noticed that it
no longer shifted into first gear, the other gears worked fine but I decided not to ride it anymore, not wanting to ruin anything else, so is this an easy fix or am I (or my Dad) looking at alot of $$ to repair this, Thanks for any feed back you might have.
If you hit you shifter it may have broken a shift fork or something. The cases most likely will have to be split.
Sounds stupid but check were the shifter mounts you might partially striped it. Alot of people forget to tighten that bolt every ounce in a while.
Actually this bike might have the notch for the bolt on the shaft.
maybe your clutch oil is low.... mine has trouble shifting into 4th and 5th when the oil gets low....
