horseman3 Posted March 28, 2010 I recently aquired a V2 under bar mount version GPR for my bike but when i go to mount it up it is resting on my steering stem nut before bottoming on my triple clamp. Anyone else run into this problem on their bike and if so could you please tell me what you did to remedy the problem. Thanks! Share this post Link to post Share on other sites
Mike in Fresno Posted March 31, 2010 there are two different mount kit models or two different dampers, one for cast triple clamps and one for machined triple clamps. Sounds like you got the wrong one. There are also some shims used by some to take make it work. Look up GPR web site. Share this post Link to post Share on other sites
spinwerx Posted April 3, 2010 Buy 10 mm or higher bar risers and they'll work. 5 mm are too low. Check www.enduroeng.com for bar riser kits. Share this post Link to post Share on other sites
