piston
Hi chaps would a 09 oem piston be ok in a 07 crf250 i know a 08 oem will be ok but was told the 09 will not, reason for asking is i have been offerd a new oem 09 piston kit.
All so i know the 08 is a bit higher comp, so is the 09 piston the same as an 08.
cheers chaps.
cheers moto-x the 09 kit is a compleat kit from honda a pal of mine has got it and has offerd it to me for half price so just wanted to make sure it would fit as he did not think it would but as i told him in the state's they run the 08 piston in the 07.
thanks for your help.
yep! anytime, just remember to install it in the correct direction! exhaust (smaller) pockets to the front of the bike.. common mistake, are you going to do the dry rebuild? (ring seat powder on the cylinder walls and a little atf or marvels mystery oil on skirts)
not doin dry build i always put a very light coating of oil in the bore never had a prob doin it this way thanks again for your help.
if your intrested please have a look at my web site not finished yet.
www.andyjamesracing.co.uk let me know what you think cheers
Smart move on your part to use oil! I've been doing it for 30 years and never had a problem! Happy trails!­čĹŹ
├Ś
├Ś
