Kx250 Plastics
Yea that looks awesome. So the front fender bolted up straight? The number plate just needed some zip ties at the bottom?
Yup, just small trimming and zip ties at the bottom. top used the same mount, the KTM plate has a hole for it.
I ran another zip tie through both bottom mount holes to give it the natural curve, if you just bolt down the top with out that it will lay too flat.
I'm working on making the rear number plates look better.
