advice on opening case 88 cr250 first time
So it's time for some open heart surgery on the old girl and I have never opened a case before. What special tools will I need to buy and what can I make? The case puller/crank pusher I saw on youtube looked expensive, as did the crank puller for putting it back in. I figure I could use my harmonic puller I use on the flywheel of my sled if I make a new plate to bolt to the case holes. I suppose I could come up with a way to make a crank puller.
What does everyone else do?
My shop quoted over $300 to open it and replace the main bearings and seals, so I'm going it alone.
Any tips/tricks would be appreciated.
i bought tusk tools from rockymountain but you can improvise on a lot of them. i saw one guy use a steering wheel puller as a splitter.
tips:
use zip lock bags to keep parts together, keep the tranny together and wrap it in foil then put in zip lock bag, take pics for future reference, and TAKE YOUR TIME
not a bad job, just double check everything.
I just got my 85 rebuilt for the first time ever probably (2003).
Full Crank Kit
Full Gaskets
Full Oil Seal
Full Piston Kit
+ Labour, Alot of money:foul:.
So the bike got all built up, now its not sparking!! 👍
