Wierd fuel system on BBB 107cc??
Just picked this up cheap today, it has spark and wants to run for a second after about 50 kicks. Its not getting much fuel if any. I tried another carb on it but it does the same thing. Wondering what the rest of this fuel system is all about? Theres a tube coming off the carb neck going up into the assembly above the carb neck, which looks like a fuel pump or something like on a snowmobile? Then there is at tube going from the assembly to the bottom of the engine, and a vent tube that goes back under the bike. I have had a couple pitbikes in the past and friends have them, never seen a fuel setup like this before? I'm thinking something is wrong with this secondary system because it won't start with too different carbs.
Gas is getting to the carb no problem, but not to the engine. Thats why I am thinking it has something to do with this vacuum system? Not drawing the mixture from the carb into the engine?
I am going to start playing with removing and blocking some hoses on it. I believe it had a vacuum operated petcock which the previous owner removed and added a manual petcock, so I think that has something to do with it
