rwomack Posted March 29, 2010 Does anyone know what could cause a drop in low-end power? Top end and valves are both fresh. Engine just seems to have lost its "bark". I am riding a gear higher everywhere!!! 👍 Share this post Link to post Share on other sites
WALKINGWOUNDED Posted March 29, 2010 Did this problem start after the fresh valves? The reason I ask is, if the problem started after the valve replacement, you may have it 1 tooth out of time. Share this post Link to post Share on other sites
oglejust Posted March 29, 2010 x2 sounds like timing is off 1 tooth Share this post Link to post Share on other sites
GTXR Posted March 29, 2010 Just a dumb question but are you riding a gear higher or a gear lower? I would think that if you where running a gear higher you would be in a lower rpm range than if you were a gear Lower?? Timing sounds like the culprit though. Have you checked the valve clearance since you broke them in? Share this post Link to post Share on other sites
rwomack Posted March 29, 2010 Thank you guys for the advice. That sounds like a possibility. It just seemed strange to be riding most tracks in 3rd and 4th gear, and now 2nd and 3rd! The problem has actually been around before and after the valve job. Share this post Link to post Share on other sites
DIKKSTARR Posted March 29, 2010 It might not be broken in yet. Mine was lazy after a rebuild, then at about 2-3hrs all the power and more came back like a switch. It was sweet! I was bummed too for awhile, until it finished seating the rings. Share this post Link to post Share on other sites
rwomack Posted March 30, 2010 Ride on...I mean right on! Thanks. Share this post Link to post Share on other sites
