Flywheel weight
I just bought a 2008 Suzuki RMZ 250, and I'm looking for a flywheel weight as i ride tight single track. I have looked at Steahly and they don't make them for the RMZ, same with Gnarly. Does anyone out there have any suggestions or know of someone who could make one.Thanks for the help Frazer.👍
Just an FYI that the Hot Rods complete crankshaft that I put in my '07 was a 1/4 lb heavier than stock and it was noticeable. For moto I had to put a lighter rotor on it to compensate. If you can't find a bolt on weight you can also look for a heavier piston which will in effect do the same thing. ProCircuit had a hi compression piston kit a couple years ago that was quite heavy...
You also might want to see if someone sells steel clutch plates for the bike. They typically make a big difference in the way the bike feels and, as an added bonus, they don't contaminate the oil the way aluminum ones do.
