hutcher Posted March 29, 2010 I was reading in MXA that they had changed the rear sproket on their 450. Having just raced on a tight track with jumps right out of the corners I was wondering if that would get me a little more punch off the bottom so I could dorner in a higher gear. Anyone tried it yet? How'd it work and what size sprocket. Wondering if I should go up 2 teeth. Share this post Link to post Share on other sites
VilleKTM Posted March 29, 2010 I´ve used 53T (one tooth bigger) on my 450 SXF´s since forever. What you need to do is get a JDkit and fix the carburation together with that 53T rear and you´ll be overjumping those out-of-the-corner jumps.👍 Share this post Link to post Share on other sites
mx875 Posted March 29, 2010 What is the stock ratio on a 2008 ktm 450sxf? (Sorry for the side topic) Share this post Link to post Share on other sites
moabrules1 Posted March 29, 2010 I geared mine taller by adding a tooth to the front. Let's me use 1st gear for starts and I can even clear ~40-50 ft obstacles in that gear. I was riding yesterday on a bigger out door track and was easily getting a fairly tight out of turn double in 3rd (~ 60ft). There's a ~ 100+ step up right after and I was having trouble getting over it in 3rd. Maybe it's my weight (160# naked) but, that gearing works for me. Stock gearing makes 1st a pit gear only for me. Also, stock gearing on that same track has me rapped in 4th a lot. Share this post Link to post Share on other sites
VilleKTM Posted March 30, 2010 Stock ratio is 14/52. Share this post Link to post Share on other sites
hutcher Posted March 31, 2010 Where did you get your 53T - On KTM Hutt the only choices for their rear sprokets are 52 or 54. Share this post Link to post Share on other sites
VilleKTM Posted March 31, 2010 I run ,and have been doing so since -03, Ironman sprockets front and rear. Best sprockets on the Planet. Period. End of story.No question. Hands down. Definitely. Cross my heart..👍🤣 Share this post Link to post Share on other sites
ktm231 Posted April 1, 2010 I run ,and have been doing so since -03, Ironman sprockets front and rear. Best sprockets on the Planet. Period. End of story.No question. Hands down. Definitely. Cross my heart..👍🤣 +1 for Ironman sprockets, longest lasting sprocket i've ever used, and i've had them on many bikes:worthy: Share this post Link to post Share on other sites
jhgsupra Posted April 1, 2010 I run ,and have been doing so since -03, Ironman sprockets front and rear. Best sprockets on the Planet. Period. End of story.No question. Hands down. Definitely. Cross my heart..👍🙂 +1 for Ironman sprockets, longest lasting sprocket i've ever used, and i've had them on many bikes:worthy: Thanks for the advice. I'll be sure to go that route next time around.🤣 Share this post Link to post Share on other sites
Havingfun My Ride Posted April 1, 2010 http://www.ktm-parts.com/mm5/merchant.mvc?Screen=PROD&Product_Code=DTIMSPKT Where did you get your 53T - On KTM Hutt the only choices for their rear sprokets are 52 or 54. Share this post Link to post Share on other sites
Havingfun My Ride Posted April 1, 2010 I do not like shifting from 1 to 2nd.. I miss the gear often going from 1 to 2, rather shift 2 up. Share this post Link to post Share on other sites
Von_Chowder Posted April 2, 2010 I am running the 14/53 setup on mine. no carb mods yet. I was wanting more bottom too. This setup gets it almost there. I bought a couple of blow-outs on rockymtn on their 54 tooths but have not unboxed them. I will probably send them back. I am used to the 53 and think 54 would be too much. I can rail ruts in 3rd....plus a little clutch action if needed to get it out on power. Share this post Link to post Share on other sites
Havingfun My Ride Posted April 2, 2010 hum, not sure what sprockets to get mine. running 14/52 stock, need to change soon. I know it sure pulls hard in 3rd 4th on large tracks. My small track at home, I am in 1 st quite a bit, 👍 Share this post Link to post Share on other sites
