1981 XT250 to 350 conversion
Hi!
I'm new to this forum. I have a 1981 XT250 that's getting tired. New cam chain, rings, etc required to bring it back into shape. However, I used to own a Yammy DS7 250, and discovered that the RD350 barrels, pistons and heads fitted straight onto the 250 crankcase 👍 - same stroke. Does anyone know if the same mod can be done with the XT250? I recall reading somewhere that the stroke of the 350 is the same as the 250.....
Cheers,
Max
if you want to do this, you need the cylinder/top end from a 350 cc yamaha quad. everything is in the same spot as it is on the xt250. have not tried to put one together but a site member did one up in a yz frame in the vintage section.
  • 7 months later...
Hello, I have 2005 yamaha scorpio. It has 225cc displacement and i think it has the same engine as xt225. I've done some engine mods about 2-3 months ago and it did work at first and blew up later on. I'm thinking about replacing the blew up parts with xt350. Therefore, a few question bothering me:
1. Is the xt350 crankcase same as xt225?
2. How much i must spend for complete head (incl. cam, valve, seals, gaskets), piston-ring, and cyl. jug?
I life in Indonesia and it's almost impossible to have these xt350 items without importing. This is the pict of yamaha scorpio:
this is the 2005-mid 2010 models
this is the late 2010 models
I doubt it.
I haven't tried it so I can't say from experience, but I wouldn't hold my breath on it, either.
The XT-350 and TT-R250 use a 4-valve cylinder head.
All of those engines you mentioned don't look like they're based on one another.
I doubt it.
okay, thanks for answering. Maybe i'll just replace it with stock parts. Thanks again!
