suspension settings
i finally got to ride after i changed my suspension settings and springs i did an 85 mile enduro in NJ ,sandy tight tree lined whoops and plenty of technical stuff no suspension feels great on these trails ...but these changes made my bike turn so much better and that is the reason i changed it. the bike didn't stand up in the turns or want to blow through the turns i just put the front wheel in the rut and gas it i could keep my feet on the pegs through most turns
Year:2005
Rider Weight: 175
Rider Weight with Gear:195
Riding Style enduro/hare scramble
Forks Raised in Triples: 1/2
Rear Tire Size: 110/90
Aftermarket Triples/Offset:
Fork Springs Wt: .43
Fork Spring Brand: factory connection
Fork Oil Amount: 340 cc
Fork Oil Brand & Weight: 5
Fork Compression: 12
Fork Rebound: 12
Fork Valving: stock
Shock Spring Wt: 5.3
Shock Spring Brand: factory connection
Shock Hi speed Compression: 3 turns
Shock Lo speed Compression: 13
Shock Rebound: 10
Shock Valving: stock
Shock Oil: 5
Race Sag: 108
From my work I have found that sliding the forks up in the tripple clamp helps a lot. I run 6mm even in the high speed trails. It keeps the front end from having that "push" feeling.
Year: 2006
Rider Weight: 230
Rider Weight with Gear: ?
Riding Style (i.e. Desert, MX): tight woods, single track, some desert trail
Forks Raised in Triples: 6mm
Front Tire Size: 80/100 MotoZ Tracula
Rear Tire Size: 110/90 MotoZ Terrapactor S/T
Aftermarket Triples/Offset: stock
Fork Springs Wt: .46kg/mm
Fork Spring Brand: RaceTech
Fork Oil Amount: 345cc
Fork Oil Brand & Weight: Maxima Race 5W
Fork Compression: 9
Fork Rebound: 13
Fork Valving: stock
Shock Spring Wt: 5.6kg/mm
Shock Spring Brand: RaceTech
Shock Hi speed Compression: "-1/4 turn
Shock Lo speed Compression: stock
Shock Rebound: stock
Shock Oil: stock
Free Sag: 15mm
Race Sag: 100mm - 105mm
Preload: ?
