will this affect anything?
hi i pulled off the valve cover today and noticed my timing marks were slightly off (yes the crank was at tdc) 2001 yz 250f
so the exhaust cam dot that is meant to be lined up alongside the head was about 0.3 4 or 5 cm up from the head.
the intake was about 0.3 4 or 5 under the line of the head.
so obviously the the idiot who set the timing before was in a rush.
would this affect my clearances as some valves were out i was just wondering if this could cause a incorrect clearance reading
won't make the clearance readings wrong unless your using the flywheel marks to set the cam positions....I usually eye ball the cam heals when checking clearances.....
  • 2 weeks later...
