exhaust baffle removed, intake restrictor not removed
I bought a 2007 crf 230 a few weeks ago. I have ridden about 12 hours with no noticeable problems--runs great. The exhaust baffle has been removed by the previous owner. The intake/air box restrictor, or baffle, is still in place. I don't know whether the previous owner re-jetted the carb or not.
Should I be concerned? I haven't noticed it running hot or anything (I use Amsoil full synthetic oil, which I understand may help on engine temp). I'm trying to get back in touch with the previous owner to see if he had the carb adjusted. In the meantime, thought I'd try to get some input from TT to see if I need to do anything if it is assumed that nothing was done to the carb. Thanks.
I'd also like an answer on this. My in-laws like to ride with their baffles removed.. which I was under the impression from reading here that that is bad for the motor? Is it safe to remove the baffle and run it with stock jetting?
My airbox restrictor/snorkel is still in. I can't seem to find a clear answer on whether there is a leanness concern when only the exhaust baffle is removed.
I'll also add that there is a slight popping on decleration. I'm going to try adjusting the fuel screw for this.
You can definitely cause a lean condition by removing the exhaust baffle. Personally I would pull the needle and jets to see what you have. Then replace them with the ones listed in the sticky as a place to start and get rid of that snorkel.
I don’t think there is a huge risk of burning your bike up with the current jetting, but you definitely want to get it dialed in. Good luck.
This weekend I was riding with my helmet cam while my bike was a bit lean from a sudden weather change.
http://www.youtube.com/watch?v=6ZE0CdVQ3Hw
At 0:32-0:34 and other parts throughout the video you will hear the bike sort of hesitate as i have the throttle just about 1/6th open. This is one characteristic of lean jetting. If it's running lean the bike might also be hard to start, and have popping on decel as you've described. Playing with your fuel screw would be a good indication of how lean you are on your pilot jet.
Thanks to everyone for the information. It doesn't have any trouble starting or any hesitation. I'm going to get with a buddy of mine who is more mechanically inclined and has more tools than I do and check the fuel screw and the spark plug this weekend to evaluate this further.
Restricting the intake system at the air filter side of the carburetor causes a rich condition just as a choke plate does.
Restricting the exhaust system causes a lean condition at high engine speeds because the incoming intake charge is diluted by spent gases in the combustion chamber that can not be evacuated due to excessive pressure in the exhaust system.
A wide open exhaust system (like a dragster) causes a lean condition at low engine speeds because the incoming intake charge is diluted by spent gases in the combustion chamber that can not be evacuated due to excessive atmospheric pressure acting directly upon the exhaust valve.
Put the stock needle and jets back in with a 45 or 48 pilot.
Okay, I've reached the following conclusion from reading this thread and another thread I located which is similar to this one:
Facts: Exhaust Baffle is removed. Intake snorkel/restrictor/baffle IS NOT removed. I am not necessarily interested in the Honda Power Up kit. I am happy with the power right now and the starting, and am only concerned that nothing detrimental to the engine is going on. I plan to leave the intake snorkel IN, and leave the exhaust baffle OUT (I don't have it anyway.) I ride at elevations of 500 to 2,000, with temp of 60 to 90.
With the above facts, I understand my options to alleviate a potential leanness concern are to EITHER replace the main jet from the stock 102 to a 120, OR to replace the pilot jet from the stock 42 to a 45.
Any comments on this are appreciated.
According to the post prior to yours you would only need to replace the pilot jet since you have an opened exhaust. You wouldn't do one or the other since they effect different throttle positions.
take the spark plug out take a pic and post it. that way we can see how well the motor is jetted. theres a good chance your running very lean.
I took the plug out last night (tried to make a picture to post but it kept turning out too blurry and wife had our good camera with her). The ceramic had a grayish/tan color, although one side was a little lighter than the other. From looking at the spark plug color chart, I think it looked pretty good, not too lean.
When I put it back in, I hand threaded it as tight as I could with my hand, then snugged it up with a spark plug wrench without much force. I understand the stock torque is 13 foot pounds, but I don't have a torque wrench. Is snugging it up okay or is it important to precisely set the torque?
It doesn't have to be perfect. Also, from what I've been told from many different sources is that you can't always use the plug as an accurate measure of richness/leanness because of all the additives in todays fuels.
Hello all, I have the same bike, 2007 crf230 and live at about 1500ft, and have not done ANY mods to it, as far as the intake/carb/exhaust goes, but would like to 'spruce it up a bit' for any free mods you can think of. I would like to remove the intake snorkle and the exhaust baffle, do I really need to get the power up kit? I just have a hard time with the carb stuff, and think it might cost a fortune to have the guys at Honda do it. I want it done right, and read the postings/sticky on this several times, but I really am not that mechanically inclined.
My question is this, can I remove the snorkel or the baffle without any harm?
Straight up. If your not getting harsh decelleration popping or back fire your not too lean. Most bikes that come as "California Models" come so lean that they back fire just goosing the throttle and you can run them their entire lifetime like that. NOW of course nobody does because even if you wanted to be really cheap you can fix the problem for less than 10 bucks or spend $50 on a kit that somebody actually took the time to develop on a dyno.
You don't really need any special skills to jet your bike if you buy a respectable kit with decent instruction (like a JD kit). Most anybody with just simple hand tools can do this and its really only a matter of loosening and then rotating the carb a smidge. I bought the jets ala cart from Honda and did my crf150F in about 15 minutes.
If you haven't seen RAMZ site yet you haven't lived....
Rick details the jetting and a mod you can make to the baffle. He will also answer your questions if you email him because he is a hella cool old fast guy. Who sent me a skid plate for free once.... what a guy.
Down there about half way you'll see everything you could have ever wanted to know about jetting in all kinds of different ways... Yup he might have a problem.
http://www.rickramsey.net/CRF230Fmods.htm
  • 4 months later...
I'm no expert by any means, but I'm in a similar situation as you.
I have all my parts and want to tune mine 230 better.
You need to do more reading.
Some facts I've found out:
1. All the bikes are lean when stock. Removing your baffle made your's more lean.
2. If you make changes like removing the snorkle or baffle you'll change the balance and need to retune. Don't think you're gonna turn a screw and fix it. Don't think changing only one part will fix it either.
Advice. IFWY, I'd get a stock baffle and install it. This will restore your bike to stock and prevent possible damage. THEN, learn to rejet yourself or pay a mech to do it right.
On my 150s (since factory bikes are lean) I'm gonna lower the stock needle and adjust the fuel screw.
On my 230, I bought the power up kit and I'm gonna start by modding the air box and exhaust. I'd like to try drilling the baffle so I can have a better breather with a quiet mode setup. I'll tune for no baffle and be able to replace it for occasional stealth mode. Next, I'm gonna change and lower the needle, change the main jet and probably the pilot. Then adjust the fuel screw as fine adjustment.
ONE GOOD SITE:
C:\Documents and Settings\Tom\Desktop\CRF230F Modifications.mht
A GOOD POST: (see next post)
repeated post on jetting PART I
Stickey: Jetting the 230F (Power-up Kit)
Remove all Advertisements
Jetting the 230F
By: Phil Vieira
This project takes no less than 2 hours if you have never done jetting to a bike before. It took me 1.5 hours, to take my bike apart, take out the needle, change my pilot jet and the main, and take pictures along the way, but I have seen the inside of my carb 3 times, so I know my way around it pretty well…
You should be jetting this bike right when you get it home. This bike comes lean from the factory. If you don’t know what that means, it means that the bike is getting too much air, in terms, a hotter engine, and your plugs will get hotter, and a decrease in HP. To make your engine last longer, do this.
These jetting combos are for a 2000 feet and below scenario. Any altitudes higher, you should do a search on the forum. If it cannot be found, post on the forum. Please don’t post on the forum “How do I do this…” You have all the answers here.
This project comes to a grand total of less than 30 dollars. The needle is 20, the main jet is about 3 dollars, and the pilot is 5 dollars. You may not need to do the pilot jet depending on your situation, but again, if you’re riding 2000 feet and below, it’s a good idea to get a pilot jet.
The jets I used consist of a 132 main, 45 pilot and the power up needle with the clip on the 4th position.
Part numbers:
16012-KPS-921 – Needle (Includes Power up needle, Clip, and needle jet)
99113-GHB-XXX0 – Main jet (Where XXX is the size)
99103-MT2-0XX0 – Pilot jet (Where XX is the size)
For the Jets, just tell them you need jets for a regular Keihn carb, (also known as a Keihn Long Hex) main jet size XXX, pilot jet size XX. They should know the part numbers. For the needle, bring the number along. If you are lazy, they should have a fiche and they can look up the numbers. Then again you can take in the old jets, and make sure they match up to the new ones.
Now, the tools you will need are as follows:
~A collecting cup of some sort. I used a peanut butter jar.
~Ratchets for the following sizes:
- 6mm, 8mm, 10mm, 12mm
- Extension for the sockets needed
~Phillips and Flathead screwdriver (Be sure these are in perfect condition. A badly worn screwdriver will strip the screws)
~Needle nose pliers
~”Vise grips” or known as locking pliers (Two)
~Open end wrench 7mm and 12mm
~ It’s a good idea to have a extra hand around
(Not needed, but I highly recommend tiny Phillips and flathead screwdrivers (Pictured next to the jar and the ¼” extension) I recommend these for removing a couple things since you can put pressure with your thumb on the end and unscrew it with the other hand. This insures that you will not over tighten any parts, and ensure that you will not strip the heads of the bolts.
Ok, now that you have the tools, let’s start by putting the bike on a bike stand. I put it on the stand rather than the kickstand because it’s more stable and sits higher. I hate working on my knees. Start by taking the number plates off. Yes, both of them. The right side, you take off one bolt and the top comes off of its rubber grommets, pull the top off, and the plate comes right off. The left hand side, use the 10mm socket to take the battery bolts off, and then take the Phillips bolt near the back. Again, rubber grommets are used to hold the top in place. Take the seat off. There are two mounting bolts on the back:
Those two bolts are both a 12mm socket. Use the open end wrench on the inside, and use the socket on the outside. You may need to use an extension if you don’t have a deep socket. Once you have the two bolts off, slide the seat back, and lift it up. This is what you have. Notice there is a hook in the middle and a knob on the tank. That is what you are sliding the seat off of.
Now that the seat is off, you must take the gas tank off. Don’t worry, you won’t spill any gas any where, I promise. On the left hand side of the bike where the valve is, slide down the metal clip holding the tube in place. Turn off the gas supply, and slip the tube off slowly. Now take off the two bolts in the front of the take. This is on the lowest part of the gas tank in the front, behind the tank shrouds. The socket you will use is an 8mm socket. Take the bolts all the way off and set them aside. Now look back at the last picture posted. On the back of the tank, there is a rubber piece connected to the knob and the frame. Slip that rubber piece off of the frame. Pull the vent tube out of the steering stem and lift the tank up. Don’t tip it, and lay the tank aside where you won’t trip on it. This is what you’ll end up with:
It may be a good idea to take a rag, and wipe all the dirt off the top of the bike if any. You don’t want anything dropping down into the carb. If you do, engine damage is the result. A clean bike is always a good thing! Now we must drain the gas out into that container. This is very easy. Make sure you open the garage door, windows, whatever, to let the fumes out. Breathing this crap is bad. Here is where the drain screw is:
(Don’t worry about removing the carb, that comes later) This is on the right side of the carb, on the float bowl. The vent tube that goes down to the bottom of the bike is where the gas drains to. Put the jar under that tube and start to unscrew that screw, enough so that the gas leaks into that jar. Once the gas doesn’t drip anymore, close the screw all the way. Now on to the top of the carb. We are going to take this cover off:
This cover comes off by removing the two screws. Once removed, the lid comes off as well as the gasket. Flip it over and set it aside. Do not set the gasket side down on the ground, as it will get contaminants! Here is what you are facing:
The angle of the camera cannot show the two screws. But one is visible. It has a red dot, and opposite of that side is a darker red dot. I made it darker because it’s not visible, but that is where it is. This is where I use the miniature screw drivers to get the screws. I magnetize the screwdrivers, and use care to make sure I don’t strip the heads. Metal pieces in a piston are not good! Remove the two screws. Put these screws on a clean surface so they do not get contaminants. Now get your vise grips and set it so that it will lock onto the throttle, not too tight, not too loose. Set the vise grips on the seat. Start to open the throttle slowly as you guide that “plunger holder” (as I call it) up to the top. Once you have the throttle all the way open, take the vise grips, and lock it so that the throttle does not go back any more. What I do is I hold it pinned and lock it up against the brake so it doesn’t rewind on me. If you don’t have locking grips, a friend will do, just have them hold the throttle open all the way until you are finished. How fold the plunger holder to the back of the carb and pull the piece up to the top. Take care not to remove it, as it is a pain to get back together! If it came apart on you, this is what it should be assembled to:
Once you get the holder out of the slider, set it back like this:
As you can see, the bar is back 45 degrees, while the holder is forward 45 degrees to make a S. Here is what you are faced with when you look down on the carb:
Where the red dot is where the needle lies. Grab needle nose pliers and carefully pull up the needle out of its slot. This is what the needle looks like once it is out.
Now we must move the carb to take the bowl off. Untie the two straps on the front and back of the carb. Don’t take them off; just loosen them until the threads are at the end. Take the front of the carb off the boot and twist the bowl as much as you can towards you. Tie the back tie down to that it does not rewind back on you. This is what you have:
Now we must take off the bowl. Some people take that hex nut off to change the main jet, which you can, but you cannot access the pilot jet, and you can’t take out the needle jet (a piece the needle slides into), so we need to take it off. It’s just three bolts. As we look at the underside of the carb, this is what you will see:
The bolts with the red square dots are the bolts you will be removing. These are Phillips head bolts, and the bolt with the blue dot is your fuel screw. This is what you will adjust when the time comes, but keep in mind where that bolt is. You need a small flat blade to adjust it.
Well, take those screws off, and you are faced with this:
The blue dot is for cross reference, which is the fuel screw once again. The green dot is the pilot jet. You can remove this using a flat blade screwdriver. Just unscrew it and pull it out. Once you pull it out, set it aside and put in the 45 pilot jet you got. The red dot is the main. You remove this by using a 6mm socket. Just unscrew it. If the whole thing turns, not just the jet, but the 7mm sized socket under it, don’t worry, that piece has to come out as well. If it doesn’t, use a 7mm to unscrew it off. Here is what the jets look like:
repeated post on jetting part2:
Pilot Jet
Main jet attached to the tube. Take the main jet off by using an open end wrench and a socket on the jet. Again, it screws right off.
Here is what you are faced with if you look form the bottom up.
From left to right: Main jet, Pilot Jet, Fuel screw. Now in the main jet’s hole, if you look closely, you see a bronze piece in the middle of that hole. We are going to take this off. Since I did not do this part (I only changed my pilot jet when I took these pictures) there are no pictures taken for this section but this is really simple to do if you’ve been a good student and know where things go. You should know anyways, you have to put the bike back together!
(Notice: There have been discussions about these needle jets being the same. Only change this needle jet if the one you have is worn out. If you do not have the old needle, a older drill bit bigger than 3/20ths (.150), and smaller than 11/100 (.11") Use the tapered side of the bit, set it down in the hole and tap it out carefully.)
Now take your OLD needle, I repeat, the OLD needle because what you are going to do next will ruin it. Pull the clip off with your needle nose pliers, or a tiny screwdriver to pry it off. Then put the needle back in the hole where it goes. That’s right, just to clarify, you took off the needle, and you put the needle back in the hole with no clip. Slide the point side first, just as it would go normally. Now if you look at the bottom of the carb, the needle is protruding past the main jets hole. Grab another pair of locking pliers (vise grips as I call them) and lock it as tight as you can on the needle. Pull with all your might on the needle. Use two hands. Have a friend hold the carb so you don’t pull it off the boot. Tell them to stick their fingers in the hole that goes to the engine, and pull up. After pulling hard, the needle jet should slip right off. Then notice which side goes towards the top of the carb. There is one side that is a smaller diameter than the other. Take the new needle jet, and push it up into the hole the way the old one was set. Just get it straight. Take the tube the main jet goes into, and start threading it in. Once you can’t tie it down anymore with a ratchet, unscrew it and look at the needle jet to make sure it’s set. That’s it for the needle jet. Now let’s start putting the carb back together.
(Notice: Many people have destroyed jets and such by overtighting them! Use the thumb on the head of the wrench and two fingers on the wrench to tighten it down.)
Thread the main jet into the tube it goes into, and then start putting it back on the carb. Thread the pilot jet in as well if you haven’t done so already. Remember these carburetor metals are soft as cheese, so don’t over tighten the jets very much. What I do is I put my thumb on the top of my ratchet, and use two fingers closest to the head of the ratchet to tighten the jet. That’s how tight I go when I tie them back in.
Now before we put the carb back together, let’s adjust the fuel screw. Take a small screwdriver, and start screwing in the fuel screw until it sets. Again, do not over tighten, just let it set. Then count back your turns. Count back 1.75 turns.
Now we must put the bowl back on. The white piece that came off with the bowl goes back as followed:
If you look directly under the carb, the round hole is aligned with the pilot jet. Take the float bowl, and put it back on.
Untie the rear clamp and the front clamp as well. Slip the carb back the way it used to. Make sure that it is straight up and down with the rest of the bike. The notch on the front boot should be aligned with the notch on the carburetor, and the notch on the carburetor should be in that slot. Tie the clamps down securely.
Let’s put the needle in. These are how the needle numbers go:
The top clip position is #1, the lowest one, closest to the bottom, is #5. (The picture says six but it is five in this case) For reference #1 is the leanest position, while 5 is the richest. I put the clip in the 4th position. Read at the bottom of the page and you can know what conditions I ride in, and you can adjust them to your preference.
Put the clip in the new needle, slip it in. Take the vise grips off your grips and start guiding the plunger holder down to the bottom. Remember not to let that assembly come apart because it is a pain in the ass to get it back together! Once you get it to the bottom, put the two screws on, and then put the cover on.
Now that you have done the carburetor mods, there is still one thing you want to do to complete the process. Don’t worry, this takes less than a minute! On the top of the air box there is a snorkel:
As you can see, you can slip your fingers in and pull it out. Do that. This lets more air in to the air box. Don’t worry about water getting in. There is a lip that is about 1/8” high that doesn’t let water in. When you wash, don’t spray a lot under the seat, but don’t worry about it too much.
The next thing you must do is remove the exhaust baffle. The screw is a torx type, or you can carefully use an allen wrench and take care not to strip it:
The screw is at the 5 o’clock position and all you do is unscrew it, reach in, and yank it out. This setup still passes the dB test. The bike runs 92 dB per AMA standards, which is acceptable. Just carry this baffle in your gear bag if the ranger is a jerk off. I’ve never had a problem, but don’t take chances.
That’s it! Start putting your tank on, seat, and covers. After you put the seat on, pull up on the front, and the middle of the seat to make sure the hooks set in place.
Turn on the bike, and take a can of WD-40. Spray the WD-40 around the boot where it meets the carburetor. If the RPM rises, you know you have a leak, and the leak must be stopped. You must do this to make sure there are no leaks!
Here is my configuration:
04’ 230F
Uni Air filter
132 Main Jet
45 Pilot Jet
Power up needle, 4th clip position
Fuel screw 1.75 turns out
Riding elevation: 2000ft - Sea level
Temperature – Around 60-90 degrees
Spark Plug Tips
When you jet your carb, a spark plug is a best friend. Make sure your spark plug is gapped correctly, (.035) but that’s not all that matters. You want to make sure the electrode is over the center, and you want the electrode to be parallel, not like a wave of a sea. Put in the plug, and run the bike for 15 mins, ride it around too then turn it off. Then take off the spark plug after letting the bike cool. The ceramic insulator should be tan, like a paper bag. If it is black, it is running rich, if it is white, it is running lean. The fuel screw should be turned out if it is running lean, and turned in if it is running rich. Go ¼ turns at a time until your plug is a nice tan color.
Making sure your bike is jetted correctly
While you are running the bike for those 15 mins to check the plug color, you want to make sure it’s jetted correctly now. Here is what the jets/needle/screw control:
0- 3/8 throttle – Pilot jet
¼ to ¾ throttle – Needle
5/8 – full throttle – Main jet
0-Full – Fuel screw
Pin the gas, does it bog much? Just put around, is it responsive? When you’re coming down a hill, the rpm’s are high and you have no hand on the throttle, does it pop? If it pops, it is lean and the pilot jet should be bigger. If it’s responsive your needle is set perfectly. You shouldn’t have to go any leaner than the 3rd position, but I put mine in the 4th position to get the most response. Your bike shouldn’t bog much when you have it pinned. If it does it is too rich of a main jet.
Determining the plug color, you will have to mess with the fuel screw.
That’s it, have fun jetting, and any questions, post on the forum, but remember to do a search first.
Also, if your bike requires different jets due to alititude, humidity, or temperature, please post the following so we can better assist you:
Average temperature
Altitude (If you do not know this, there is a link in the Jetting forum that you can look up your alititude)
Average Humidity
What jets you are currently running
What the problem is (If there is one)
Just do that and we'll help you out the best we can.
EDIT: The girl using this login name is my girlfriend. You can reach me on my new login name at 250Thumpher
Then again, you're more than welcome to say hi to her!
-Phill Vieira
