Rannoch Posted March 29, 2010 Click for picture Never had the occasion to look for hubs before, but now that I do, I'm finding that it's really hard to find just a hub for sale. Complete wheel kits are no less than $400. I can buy wheels for my car for less. Can anybody point me in the direction of just a hub that will work with my stock 18x2.15 rim? Or even a cheap wheel kit. Rockymountain has their g-force brand, but its only 19". Or, does anybody have a used hub for sale? Thanks Share this post Link to post Share on other sites
joebiodiesel Posted March 29, 2010 I don't have a suggestion for finding a cheap replacement, but last time I saw a hub broken like that I was told it was from running the chain too tight. Not saying you did that, but it's something to be mindful of. Joe Share this post Link to post Share on other sites
cubera My Ride Posted March 30, 2010 Wow....Did a rock blow a hole in it? That's weird.....I would search around for a good used hub or maybe buy a complete rear wheel. Share this post Link to post Share on other sites
sbest My Rides (9) Posted March 30, 2010 A 19" hub will work, as long as it is for 36 spokes. The only difference between 18" and 19" is the rim and spoke length. Any used KTM hub will work from the mid-90s to present I believe. Some aftermarket is different. Yeah, how did that happen? That is wild. I just did a rim: Share this post Link to post Share on other sites
ktm300 My Ride Posted March 30, 2010 Been there, you can get a whole wheel for what just the hub cost. Share this post Link to post Share on other sites
Ud_Luz My Rides (3) Posted March 30, 2010 Classic case of the chain too tight. You're lucky, it could have been the engine case that failed. Time to hit up eBay and ktmtalk. Share this post Link to post Share on other sites
Rannoch Posted March 30, 2010 I actually went out today and took a look at my chain. Its well within spec, if anything its a little loose. Sprocket condition is perfect, I think I have 4 rides on that set. I've probably only put 100 miles on the bike since I got it, so its quite possible the previous owner ran it too tight and started the process. Thanks for the replies. Share this post Link to post Share on other sites
Zappa Posted March 30, 2010 I would guess that would be a wheel bearing that was left too long and disintegrated itself. I think from the picture I can see new grooves that the balls wore in the spacer from being able to freely move around in there. I have seen other pictures of other hubs that look very similar after loosing a wheel bearing. Share this post Link to post Share on other sites
swedishfishmx Posted March 30, 2010 Yep I've seen wheel bearings do number on a hub before. Share this post Link to post Share on other sites
sbest My Rides (9) Posted March 31, 2010 Usually the chain is plenty loose after a failure. The chain on these has to be deceiving loose at normal sag. If you disconnect the shock and perfectly align the front and rear sprockets with the swingarm bushing, you can tighten up the chain to "snug" and then see how it loosens as it goes through its travel. It will really surprise you. If you overtighten the chain even just a little bit, it puts HUGE forces on the hub and countershaft. Share this post Link to post Share on other sites
Rannoch Posted March 31, 2010 Zappa, I believe youre right. The bearing on the sprocket side of the hub is gone, and that thing in the pic is the oil seal. I even have new bearings in my garage. The ones on the bike were fine three or four rides ago, guess that'll teach me to check more often. Share this post Link to post Share on other sites
Rannoch Posted April 11, 2010 Will a 2006 KTM300 wheel fit on my 02? I'm having a hard time finding part numbers. Thanks! Also, the hub from an 02 520EXC, will that work? Share this post Link to post Share on other sites
Gary jp4 Posted April 11, 2010 (edited) After a few years or on older bikes, have you ever had spokes seize up and had to cut them off just because they were loose and you couldn't tighten them? All this after taking the wheel and tire off to get to the other side and try to heat them up, let penetrating oil sit for days, hold them with vice grips to keep them from turning in the hub, etc. Sometimes those things work sometimes you have to cut them off. TIP: If you are putting new spokes on, put some regular aluminum anti-seize on the threads so this never happens. Has worked for me over the years. Edited April 12, 2010 by Gary jp4 Share this post Link to post Share on other sites
