John In NC Posted March 30, 2010 I have been looking for OEM rear turn/tail light connectors with no luck. The only thing I have found is to buy the entire tail light or turn signal light assembly. The actual piece I'm interested in is the end of the turn signal that connects to the bikes wiring. I have a custom LED set up that won't pass inspection. I'm getting tired of re-soldering it once a year. My bike is a DRZ 400s. Share this post Link to post Share on other sites
tedhone Posted March 30, 2010 Google Motorcycle wiring connectors. Vintage connections, Eastern Beaver there are a bunch of people that sell them Share this post Link to post Share on other sites
gtlegacy Posted March 30, 2010 http://base0.googlehosted.com/base_media?q=http://www.bmotorsports.com/shop/images/conn-75555.jpg&size=18&dhm=7baa9f6&hl=en I use these connectors for all of my automotive and motorcycle applications. They are easy to use and are water proof. you can buy good assortments on ebay, and they do not require soldering. Delphi connectors! Waytecwire.com has these http://order.waytekwire.com/IMAGES/M37/items/30966TH.GIF which are butt connectors that solder in the middle and shrink (waterproof) when heat is applied. T Share this post Link to post Share on other sites
Aaron_Silidker Posted March 30, 2010 k&l motorcycle should have what you need. Share this post Link to post Share on other sites
William1 My Rides (2) Posted March 30, 2010 There are no suppliers in the US that have the turn signal plugs. If you have a friendly supply house person, you may be able to match up the pins and be able to reuse the shell. Share this post Link to post Share on other sites
