JohanChaves Posted March 30, 2010 Hi I own a 95 XR 250L and I am working on its look(want it to look 2000 on) , I will work on its motor/frame paint, also using 400R rear fender and brake light unit, graphics, and 4R front head light assembly and front plate ( red and white ones) Do any of you guys have any odd photos from the head light and front plastics so that I would know what am I dealing with? Also any recomendations will be apreciated.👍 Share this post Link to post Share on other sites
ThumperTDC Posted March 30, 2010 So does it have a metal tank on it? If it does, one thing you may try would be to see about doing to metal work to it to add shrouds off a newer CRF to change the entire look of the bike. Add a CRF front fender (I think it looks alot better then the stock XR250/400 front fender) Another thing to add that will update the look would be going with a CRF/X headlight. THe thing with the XR250/400 rear fender is that it has the side number plates that form into it. The previous 250 has a gap between the side plates and the rear fender. If it were me, I would use a MX rear fender off a CR/CRF and then if you needed a rear tail light, add an aftermarket light used for a dual sport that mounts under the fender.............Just a thought. Share this post Link to post Share on other sites
ThumperTDC Posted March 30, 2010 Just looked at you bike in your garage and noticed that you have already dont some of the things I mentioned. Your bike looks pretty sweet for an older XR. Share this post Link to post Share on other sites
JoeBlow Kokomo Posted March 30, 2010 Nicest looking XLR 250 I've seen. Nice! Share this post Link to post Share on other sites
JohanChaves Posted March 30, 2010 I know my bike is a little old and dont pretend it to look like a brand new CRF or something is that far from, still will use a CRF front fender but I dont know about the shrouds, alllready have a rear fender from a CRF but don´t know, I makes it look longer and somehow lower rear ended, there is a guy doing a glassfiber work on the XR4 rear fender so it fits my XR almost OEM like!! I was wondering if you had photos from the headlight assembly, you know just to know how should I adapt it. Thanks for your recomendations if u have more they are apreciated. Share this post Link to post Share on other sites
