1buck Posted March 30, 2010 Looking to invest in a steering dampener for the 450EXC- Trying to decide on a top mounted or bottom mounted- what are the pros & cons? Preferred brand?: price-function-customer support Thanks Share this post Link to post Share on other sites
marine89 Posted March 30, 2010 I'm only 5' 9" tall and i run the submount and CR high bars on an 06' 450 exc. i'm mostly a stand up rider. it just depends on your height and style of riding really. plus you need to feel comfortable. with your current set up do you feel your bar height is fine or would you prefer them a little higher? if you want them taller go with a submount if not go with a top mount. I only use scotts dampers and i have not tried any other one so i can not compare them to the others out there. Share this post Link to post Share on other sites
jgiachino Posted March 30, 2010 I have a scotts on my 450 and just got a motosportz submount for my 530....cant go wrong either way, motosports was cheaper, smaller, simpler, easier to install and for the 20 hours i have on it, it's just as good. Share this post Link to post Share on other sites
cr rabbit Posted March 30, 2010 I'm only 5' 9" tall and i run the submount and CR high bars on an 06' 450 exc. i'm mostly a stand up rider. it just depends on your height and style of riding really. plus you need to feel comfortable. with your current set up do you feel your bar height is fine or would you prefer them a little higher? if you want them taller go with a submount if not go with a top mount. I only use scotts dampers and i have not tried any other one so i can not compare them to the others out there. At 6'1" I need the height a sub mount offers. I use a GPR dampener, they are local for me and the customer service is top notch. However I think the scotts is better unit overall. The GPR dampens all the time, sort of like the steering head is to tight, and the steering input can seam heavy. But you get used to it. Share this post Link to post Share on other sites
creeky Posted March 30, 2010 I have a WER damper on my 450EXC, very happy with it. Share this post Link to post Share on other sites
8675309 My Ride Posted March 30, 2010 i run motosportz sub and also have scotts sub on my yami, both work well. i like tall bars. Share this post Link to post Share on other sites
wvdualsport My Ride Posted March 30, 2010 I have a Scotts Sub mount laying here in the box waiting for the weekend to mount on my 450 EXC. I already have bar risers on it, so the mount will not be an issue for me at 6', I like my bars pretty high and forward ( really long arms). Share this post Link to post Share on other sites
lopaca Posted March 31, 2010 I went with GPR (my dealer had it in stock). I chose to go with the sub mount because I wanted the bars higher anyways. I sure love having it. I was on a dry lake bed and heavy sand this past weekend out at Johnson Valley and had the thing cranked way up. It made the high speeds on the lake bed comfortable and the sand was much more doable because I wasn't fighting the front wheel. Get one. Share this post Link to post Share on other sites
Canadian K My Ride Posted March 31, 2010 I've been very happy with my GPR underbar stabilizer (KTM orange - from hardparts catalogue). I bought it in 07 with my 450EXC and it is still working great. I'm 6' and the additional bar height was perfect for me (especially for standup riding). Once you ride with a stabilizer you won't want to go back to riding without one. Share this post Link to post Share on other sites
1buck Posted March 31, 2010 Thanks for all the good input-👍. I prefer a taller set up- Im 6'1" and it helps my standing riding. I have taller bars arriving today and plan to install these before I pull the trigger on a dampener. I have two bars to try one is 13mm higher than stock and the other are 20mm( pastrana FMX) higher than stock, so I guess I would be leaning towards the top mounted stabilizer-because I dont think there will be enough cable to go any higher. It kooks like some had problems with cable length- throttle- brake lines- ect. Does anyone know about how much rise you can add before you run into problems: 10mm-15mm-20mm+? Thanks Share this post Link to post Share on other sites
Canadian K My Ride Posted April 8, 2010 I am still using the stock cable length with the GPR raising the bars 20+ mm. That is about max for the stock cables, though. Note - I have also cut the stock bar width down by about an inch on each side. Share this post Link to post Share on other sites
Jonnoh Posted April 8, 2010 I've only used a scotts, but I can say the quality is excellent. I have had the same scotts since 2001. I had it on my 01 YZ250, 03 KTM 300, 05 CRF450, and I am planning on getting the mount to set it up on my new (to me) 08 450EXC. I am going with the top mount because I kept my CRF and I can swap it back and forth. I have had it serviced once and probably need it again just for peace of mind. I use the adjustment quite a bit. I usually set it at one full turn out for desert and 2 for the tighter stuff. Anyone have issues with the throttle cable routing with the stabilizer on the EXC's as the cable routes to the front of the bars... right where the stabilizer meets the post? Share this post Link to post Share on other sites
1buck Posted April 8, 2010 Looks like I'll to go with the Scotts top mount set up. From the input here(many thanks), and several other riders Ive talked to, Scotts seems to come out on top be the benchmark for dampeners: quality- durability-performance-support. FYI- regarding cable length and how much height you can add before changing to longer cables: I've swapped out the OEM Nekken (95mm high) and put on the ProTaper Contour Pastrana FMX(121mm high) which puts the rise about 26mm higher than the OEM Nekken bar- cables are fine- theres no binding- but there isn't much more free play left so I wouldnt imagine going to a higher set up with out going to longer cables. Share this post Link to post Share on other sites
cr500at53 Posted June 24, 2010 if you happen to oun a 450 or 530 08 munn racing has a GPR for 299.00 if they have any more. Share this post Link to post Share on other sites
PBDBLUE Posted June 24, 2010 I have had Scotts on all my bikes for years. When I bought the '07 450 EXC the po had installed the GPR submount. I like the submount setup but not really sold on the GPR stabilizer. As mentioned earlier it dampens in both directions and is felt more by the rider than the Scotts. The Scotts seems to have better hi-speed dampening while maintaining more of a "free" feel during normal turn of the bars. If I had it to do over I'd go with Scotts but the GPR gets the job done. Share this post Link to post Share on other sites
Captain Dogmeat Posted June 27, 2010 I just installed the Scotts stabilizer on my 09' 530 today, took it out for a ride... I'm running it pretty soft right now, but I do like the additional height on the bars ... I'm 6'4" .... The complete scotts kit was $490 .... not too bad of a price for an adjustable unit. Share this post Link to post Share on other sites
chrisford4x4 Posted July 2, 2010 I've got a GPR submount on mine and love it. It is the fist stablizer i've had on a bike and won't eber go with out one!! I was riding over some large rocks with a friend that was struggling with out one while i was flouting over them on mine. Share this post Link to post Share on other sites
Danco Posted July 5, 2010 Scotts on a BRP triple clamp and sub mount. Share this post Link to post Share on other sites
kawasakimx8 Posted July 5, 2010 go with RTT, its built into the top triple clamp and they do not raise ur bar heighth at all, and its not sticking out the top. Share this post Link to post Share on other sites
mikeythefokker Posted July 5, 2010 The rtt has been a problem for a friend of mine ever since he got it. It needs to be serviced much more frequently than a scotts. The design is pretty slick though, and the on the fly thumb adjust is really cool. The scotts is a better stabilizer, but it doesn't mount as slick as the rtt. If you are getting a scotts and starting from scratch, I'd get the undermount. You can always get lower bars if you do not like them raised. Share this post Link to post Share on other sites
