sandagesr Posted March 30, 2010 Alright. I have to remove my air filter and place my hand over the hole to get my bike to start. What's up with this and how do I fix it? Share this post Link to post Share on other sites
ThumpNRed Posted March 30, 2010 Sounds like you are manually choking your bike. I have had bikes that ran like crap off the choke and it turned out to be a fouled plug. A place to start. Share this post Link to post Share on other sites
zx12r Posted March 30, 2010 Alright. I have to remove my air filter and place my hand over the hole to get my bike to start. What's up with this and how do I fix it? If it's not the plug, it's your carb or a vacuum, air leak. not getting enough fuel. Share this post Link to post Share on other sites
fishpost19 Posted March 30, 2010 Do you have to have your hand over the inlet for it to keep running, or just to start? If it is fine when it warms up, maybe your choke plate is broken, chokes not working, and you can start it by manually choking it Share this post Link to post Share on other sites
sandagesr Posted March 30, 2010 Do you have to have your hand over the inlet for it to keep running, or just to start? If it is fine when it warms up, maybe your choke plate is broken, chokes not working, and you can start it by manually choking it It is fine after it warms up, and I often only have to do that for the first start of the day. Share this post Link to post Share on other sites
gunz Posted March 30, 2010 is the manual choke working? May be a carb that needs to be cleaned out. Share this post Link to post Share on other sites
keithluneau Posted March 30, 2010 What year is the bike? Does it have a choke flap in the carb, are the "enricher circuit" type choke with a plunger? If it's got the plunger, maybe the circuit is stopped up and not letting it draw fuel. If it has the flap, or butterfly choke, make sure the flap is still in there and fastened to the shaft. That flap is there to do basically what you're doing with the hand, restrict the air at the back of the carb so it pulls more fuel through the jets. Share this post Link to post Share on other sites
brichter My Rides (5) Posted April 4, 2010 Probably had the plate, ingested it and spit it out the exhaust. Lucky, lucky! Share this post Link to post Share on other sites
MetricThump Posted April 13, 2010 is the manual choke working? May be a carb that needs to be cleaned out. may be worthwhile to just dip the carb in carb dip and clean her all out! Share this post Link to post Share on other sites
