Bag Bolts
Anyone know what size the bolts are on the rear fender that hold the bag on? I ask because my DRZ is being delivered tomorrow and the bolts on it are a bit weathered and rusty and I'd like to replace them.
Cheers 👍
M6x1.0 pitch. i can't help on the length. if i had to guess, i'd say at least 17 mm long.
either remove one & measure or just bring it with you to the hardware store.
If you use the stock aluminum "washer" in the bag... you will need standard Socket head cap bolts.
Also, you may need bolts closer to 20mm long. You will need to go through the washer, the plastic bucket of the bag, the fender, and you will want 6mm for the nut in the frame.
Last thought... since you are ordering bolts... get stainless steel. that way they wont rust again.
