Ssr-125
most likely it is the screw underneather the carb, a flat head. We make a adjuster for it so you can adjust it with out having to pull it off everytime.
Yeah, there is a flat head screw beside the overflow tube. Is that it? I'll get pictures of it and edit this post in a few minutes.
Alright, I found the screw. It's the one under the carb. I have to remove it every time to adjust it. I've got it running sorta alright right now except for 1st and 2nd gear it acts funny. 3rd and 4th is running better than ever. Does this mean it's running to lean? I turned it all the way in and ran it for like 5mins. Turned it off, took plug out. Plug was lean looking. Adjusted screw two times outwards and waiting for it to cool down to see if it's still to lean because it is still acting funny in 1st and 2nd gear. How many screws out from all the way in is usually perfect? I don't want to have to remove the carb like 10 times just to adjust that screw.
├Ś
├Ś
