2008 TE-610 Axle size question
on the commute bus, headed into town.....
Anyone know the size of the allen wrench needed for the left side of the front axle.
I have had NO cofffee
I have no brain...... 🤣
I can NOT remember the size.......
HR
12mm and a little hard to find. Many change to the 15 mm axle nut from either Uptite or Motosportz, stainless for Uptite or aluminum for Motosportz, about $30. This allows a double ended wrench to handle both axles. Available in a kit of sorts from Cafe Husky ...http://www.cafehusky.com/forums/forumdisplay.php?f=53
If you're lucky you can get it out with two 6mm hex stuck in there...in a pinch. Well, it worked in Baja once for sure.
