How long is castor927 good for
I mixed 40:1 about 10 days ago using castor927 and 1 out of the 10 days the temperature reached below 35 at night. The low was 28 and I read on the bottle that the stuff may seperate at temperatures below 35 and my gas was in my little shed outside with the bike. Do you guys think I'm safe to use this; have any of you used castor that has sat in cold temps. Also how can I tell if it has separated 👍
may separate..... So mix it again...its oil......My dad still uses stuff from the 80's in his chainsaws without issue....(mineral that is0...and I even ran a quart through my 85 at one point without issue....(cept for splooge)
Also how can I tell if it has separated 🤣
Before I switched to Klotz Super Techniplate I made the mistake of using Castor 927 in 5 gallons of AVGAS even though the label said it could separate in temperatures under 35. All the oil was sitting on the bottom of my VP jug when it was 70. It was fairly easy to see that all of it had settled.
Just shake the can up and keep an eye on it 👍
