Compression Ratios
It depends. You have to look at ignition timing and valve overlap, etc... a long with the comp ratio. One engine may get by on pump at 13.5:1 while another may need higher octane at 12.5:1. Best bet is to talk with the piston supplier about your specific bike if you're looking at a high comp setup.
