07 ktm sx150 oem fork/shock valving
base is
24.15(3)
14.1
24.15(4)
down to in even numbers
12.15
9.5 clamp
mid is
20.1(5)
18.1
11 clamp
0.45mm lift
1.2 bar
385cc
4.2 spring
18 comp setting std
21 rebound std
this mid is not too bad with less lift.
the base is just horrible, in a horrible world, surrounded by horrible things.
This bike has a stock 450 spring on the rear and 2 sizes up spring rate in the front. The rider is 5'8' 160lb intermediate mx guy.
Any suggestions on fork/shock valving to improve this ride
its hard to say really, but if you replaced all the 0.15mm shims for 0.1mm it will be much better, this fork requires a lot of work to get good.
