125sx 144sx torque values
I've written down quite a few accurate torque values for my 09' 150sx and I though I should share some of it with you guys..
84" pounds for clutch case and water pump bolts
100" inch pounds for oil drain bolt on clutch side and coolant drain plug
180" pounds for drain bolt on shifter side
70" inch pounds for oil check bolt
13 pounds for cylinder head bolts
700cc of tranny oil
60lb for rear axel
12 foot pounds for triple clamp bolts
Though it might be some help to fellow two strokers out there
