Crankcases
You're in luck.. :applause: i just happen to have a right side case for an 07 that "may" fit 👍 Not positive though.. I think the difference is the recess for the kick starter shaft?? 🤣
Anyone know if I can sell my case to this fella in need 🙂
you might be able to weld it back together depending on where it broke. take it to a welding shop and see if they can do anything for you. it will save u sum big bucks if they can.
That is what I did. The guy did an excellent job. Thanks!
You're in luck.. :jawdrop: i just happen to have a right side case for an 07 that "may" fit 🤣 Not positive though.. I think the difference is the recess for the kick starter shaft?? 🙂
Anyone know if I can sell my case to this fella in need :applause:
Thanks for the offer, but my cases are good as new now 👍:thumbsup: Thanks for all your help!
