03 crf 450 jetting for FMF powercore 4? starting probs
i bought a dynojet kit and installed it on the bike, the bike ran fine but had a little bog but picked up instantly i was wondering if u just have to live with that or can it b fixed ,(it's on a cruising then WOT punch). i never adjusted the mixture screw on the carb, but did after i rode it. i set it to there spec of 1 and a half turns out , after that the bike wont start so i have it turned out around 4 or 5 turns out. but the bike pops somtimes when i try to start it . it takes a while to start and i have to twist the throttle slightly to make it start. when warm sometime i have to repeat that procedure
all i have it a fmf powercore 4 and a boyessen quickshot pump
ride under 3000ft prolly around 1000
i was wondering if the jetting is even needed with this pipe??
i also just bought a rev box trying to see if this will help with the starting
also the bike started fine before i turned the screw and when the bike was stock started perfect hot and cold. it also started hard after a fall or trail riding at slow speeds
