Kx250f Starting problem
I need help. The only way to start my bike cold is to twist the throttle when starting it, even with the choke on. Is it running lean? I just cleaned the carb and adjusted the intake valves 2 rides ago. I went camping over the weekend and it started pouring down raining in the middle of the night with the bike outside, could that of messed with something? It started perfect 1st kick hot or cold before the trip. so what do you think it is?
P.s. i clean my air filter after every ride if that helps
