fcr slide / throttle cable wheel stuck
So it seems my slide is not descending all the way. Here are some pics:
It looks like the rollers should be back flush against the wall.
Here's a pic of the side. I looks like the wheel is stuck and not hitting the screw that should stop the throttle.
Any help? Thanks!
Pull the throttle shaft out, and push the black plastic bellcrank back onto the top of the AP rod. The top of the rod has a ball on it, and it will snap into the section where that little window is. Once it's back... you can re-install the throttle shaft.
Thanks guys! I pulled the throttle shaft out after fighting with the screw. Reset it and threw it back in the bike. She runs like a champ now! So happy with the results. I'll do a little fine tuning tomorrow with the adjustment screw and sit the air boot a little better on the carb. Thanks again for all your help!
