nicho627gb Posted March 31, 2010 HI iv got mrd/ssw and doing 3x3 mod, just need help with jetting, what do i need to do with the pilot air jer. paj, do i need to buy a specific one or can i just buy the jd kit and have every think i need. jetting specs of eddie 160 main jet jd blue clip 4 25 pilot jet with the stock fuel screw 2.75 turns i belive what he tells me but does not mention any think about piot air jet thanks for any help Share this post Link to post Share on other sites
zac949 Posted March 31, 2010 (edited) A JD kit has everything you need including a range of jets suited for your altitude.(kit has only one pj) The most important part of the kit is the red and blue needle. The jets though are standard size you can order online or from any shop. Edited April 1, 2010 by zac949 Share this post Link to post Share on other sites
Harvey600 Posted March 31, 2010 The kit has Pilot jet, not pilot air jet. You'll need to get pilot air jet from Allensperformance.co.uk, you can get main jets from there too. Share this post Link to post Share on other sites
spokis Posted March 31, 2010 you need to change from a 165 PAJ (under the diaphram in the top of the carb) to US spec 135.. You can get it online from any US spec OEM parts list. this is done to convert to a "US spec carb" so you can use the wealth of jetting knowledge from the TT forum. otherwise you can experiment with a bigger pilot (fuel) jet which you can probably source locally EU bikes are leaner to pass Euro3 regulations Share this post Link to post Share on other sites
nicho627gb Posted March 31, 2010 you need to change from a 165 PAJ (under the diaphram in the top of the carb) to US spec 135.. You can get it online from any US spec OEM parts list. this is done to convert to a "US spec carb" so you can use the wealth of jetting knowledge from the TT forum. otherwise you can experiment with a bigger pilot (fuel) jet which you can probably source locally EU bikes are leaner to pass Euro3 regulations thanks thats the info i wanted 👍 Share this post Link to post Share on other sites
