mandark Posted March 31, 2010 I'm asking here because it seems the Yammy 2T crowd is far more forthcoming with information than our Dual Sport bretheren. I ordered a set of dirt wheels & rims for my WR250X. I need to order a rear sprocket and chain for it to facilitate quick changes between the two sets of tires so I decided to go with a 13/47 setup. How long of a chain I will need? 110? Share this post Link to post Share on other sites
ForsheeMS Posted March 31, 2010 Most of the 520 chains I've bought come in 120 links which should be a little too long. From there you just cut to fit. Share this post Link to post Share on other sites
shrubitup Posted March 31, 2010 Great question but we prolly don't know the WR250X dimensions too well. I owned a china bike for a month because it was only $150. It needed a new chain so I bought a 428 style chain. I guestimated two different lengths and they were both too short. Had to splice from the shortest to make the longer of the two long enough to fit. I suggest the 120 link chain and then cut - OR - either remove and count your existing links or count them in place on the bike and then add a few for the new gearing but you can see that's more guestimation whereas the 120 link is fail-safe. Rockymtnatv says you have a 520x108 chain with 13/42 gearing stock. So prolly 112 or 114 length but I would buy 120 to be sure. Share this post Link to post Share on other sites
mandark Posted March 31, 2010 Great question but we prolly don't know the WR250X dimensions too well. I owned a china bike for a month because it was only $150. It needed a new chain so I bought a 428 style chain. I guestimated two different lengths and they were both too short. Had to splice from the shortest to make the longer of the two long enough to fit. I suggest the 120 link chain and then cut - OR - either remove and count your existing links or count them in place on the bike and then add a few for the new gearing but you can see that's more guestimation whereas the 120 link is fail-safe. Rockymtnatv says you have a 520x108 chain with 13/42 gearing stock. So prolly 112 or 114 length but I would buy 120 to be sure. Thanks for the suggestions guys! I'll pick up a 120 and a chain cutter. Share this post Link to post Share on other sites
OREGONMX Posted March 31, 2010 I need to order a rear sprocket and chain for it to facilitate quick changes between the two sets of tires so I decided to go with a 13/47 setup. I'm a big fan of saving money- Rocky Mountain ATV has a great house brand that is way cheap and has held up great for me- $89 for a gold X-ring chain and a STEEL front AND back sprockets (steel lasts forever compared to aluminum). Had mine for over a year and only had to adjust it after the first ride- Boom! http://www.rockymountainatvmc.com/vehicleSelectProd.do?prevVehicleType=2&prevMake=8&prevModel=737&keyword=&vehicleTypeId=2&make=8&model=737&applyFilter=Change+Vehicle&year=2009&navTitle=Drive&navType=type&webCatId=9&webTypeId=123&prodFamilyId=2218&stockId=&listingId=&uri=/productDetail.do#vehicleSelect Share this post Link to post Share on other sites
NP4M Posted April 1, 2010 I just went through a similiar thing on my YZ250. I counted 115 (???), ordered a 116, and had to cut two links off. Running 14/48 on that bike is a 114 link chain, if that helps you get a point of reference. Nothing like spending $100 on a chain and having to take the grinder to it right away.... Share this post Link to post Share on other sites
Matt_W Posted April 1, 2010 Thanks for the suggestions guys! I'll pick up a 120 and a chain cutter. I'm all for having the right tools for the job, but you don't need a chain cutter for this job. I use a bench grinder and just grind the pins flush with the plate, then use a screw driver to pry the plate off. It literally takes me less than a minute to grind the pins down and pop the plate off with a bench grinder. You can also use a dremel to do the same thing, but it will take you a bit longer 👍. Share this post Link to post Share on other sites
j_schuetz Posted June 28, 2010 I have a 2008 wr250x and I am looking to change my sprockets to a 12T in front and a 45T in rear. Was wondering what size chain will I need to buy and will I need to buy a speedo healer. If I need to buy a speedo healer what brand is better and where to buy it. Share this post Link to post Share on other sites
