False speedometer reading
Bike is stationery, just by applying throttle to rev the engine, the speedo is actually reporting speed. The higher the revs the higher the speed .... for a second I thought I magically somehow found an easter egg ... functional tach on a stock clock 👍
Under any other condition it seems to function fine. I am trying to recall whether the same was happening last year before season ended and must say that I don't think so.
It doesn't make any sense does it?
I'll check the speedo cable, but it doesn't make sense. If it was loose there would be false reading all the time when the bike is stationery which it is not.
If the cable is fine, I will bug the dealer, as it's still under warranty ....
BTW, someone asked, it is the stock unit, not aftermarket.
