new2dualsport Posted April 1, 2010 Been a while since I wrenched on a bike. I have been desmogging, carb modding, sprocket chain replacing etc. I noticed tonight when I removed my chain the front sprocket could be moved in and out a bit is this normal? Also the sprocket had a plastic ring down approximately 1/2" from the tip of the tooth down toward the center kind of a guide for the chain, will a new aftermarket sprocket come like this or is this a factory thing? Thanks Share this post Link to post Share on other sites
brianhare My Ride Posted April 1, 2010 Been a while since I wrenched on a bike. I have been desmogging, carb modding, sprocket chain replacing etc. I noticed tonight when I removed my chain the front sprocket could be moved in and out a bit is this normal? Also the sprocket had a plastic ring down approximately 1/2" from the tip of the tooth down toward the center kind of a guide for the chain, will a new aftermarket sprocket come like this or is this a factory thing? Thanks Sprocket rubber thing is factory,,i think it dampens chain noise,not positive though,aftermarket does not have this.. sprocket and shaft movement in and out is normal,,check the sprocket retainer for wear,and the output shaft for wear.. B Share this post Link to post Share on other sites
new2dualsport Posted April 1, 2010 thanks for the heads up Share this post Link to post Share on other sites
akarob Posted April 1, 2010 The keeper should keep it fairly tight in the in/out direction. You can see wear very easily if you take it apart and clean it. Look at and clean the splines, they tend to strip if neglected. Reassemble with some grease on the splines. Share this post Link to post Share on other sites
XR-Cyclone Posted April 10, 2010 I took my chain off today and and noticed the same play and thought nothing of it. I put the bike in first gear so I could loosen the retainer bolts and noticed some play in being able to turn the output shaft I would say enough to where the outside of the sprocket would move about 1/2" on it's diameter before slack is out. At the shaft it is probably moves a little greater then the width of the spline. Is that normal? Share this post Link to post Share on other sites
HeadTrauma Posted April 10, 2010 Is that normal? Yes it is. It's just backlash in the gearbox. Share this post Link to post Share on other sites
