Yz426f Front fork (outer tube ) help/ opinion !!!!
I am redoing my fork seals. my right outer fork tube is bent in just a little bit probablly 3/4" inch in length and its bent in so it is straight. the inner tube came out but the fork seal and one of the bushings stayed in there. do you think that i could just replace everything and it would be ok. or do you think that it will be bad the fork leaked a little bit but i am pretty sure its because of 10 yr old fork seals and dusters and bushings.
