'03 wheels on a '01 CR250??
I have a an '01 CR250. Some spokes on rear rim are bent and won't tighten, just keep spinning. I was going to pick up a set of G-Force complete wheels from Rocky Mountain MC. Problem is they only make them for for 02 and newer. I read that I just need to switch rear break rotor for a newer one. Is this true? Anything else I need to know about a wheel swap? Thanks.
01 cr250 rear hub:
5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450
Front hub:
14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F
03 cr125 front hub:
194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09
Some of this is available here:
http://home.comcast.net/~motoxmann/ENGINE%20ID.htm
