41mm fcr leaking!!!
Ive got a 41mm fcr on my ltz400 I know its not a drz but I figured you guys know alot so I figured this was the best place for it. Anyways I dont have my vacum line hooked up yet to work the diaphram on the petcock so I just put it on prime and for some reson It spews gas out everywhere when the motor is not running. It is a brand new carb ment for a z400 bought from trinity racing. Does my carb not have a float shut off so when the bowl is full the gas stops running. Or am I going to have to take it off and adjust it. Also is there a place to plug my vacum line on the carb to make my petcock work?
thanks
It's possible that the float is stuck, you can try a light tap on the float bowl to try and knock it loose. If that doesn't work you may need to remove the carb and verify that everythings ok in the bowl.
