trenchpig Posted April 1, 2010 Is it safe to haul Raptors on end or at least at a 45 degree angle on my trailer? (without the oil or gas leaking all over the place) Share this post Link to post Share on other sites
tech24 Posted April 1, 2010 You might have some coolant seep out of the overflow but I used to store mine that way due to space limitations. You'll get a little fuel out of the carbs unless you run the carbs empty (assuming its not a 700). Should be fine. Share this post Link to post Share on other sites
