2strk Posted April 1, 2010 what weight engine oil is good to run?? and whats a good tranny oil to run? and how often to change? Share this post Link to post Share on other sites
KcDavis My Ride Posted April 1, 2010 You can pretty much run anything in the tranny. I personally use ATF and love the performance. I probably change it every 2 rides. You mix the "engine" oil in the gas via 2t oil. Just pick your favorite kind and mix it up. Most people mix anywhere from 32:1 - 40:1. But I am sure you will hear all kinds of different opinions because everyone is always right. I would suggest that you get a manual, it sounds like you need one. Share this post Link to post Share on other sites
2strk Posted April 1, 2010 and how much tranny oil to put?? and is there a indacator wehen im full? also you need tranny oi premix oil and engine oil right' whats a good weight to run in the engine 10 w 40? Share this post Link to post Share on other sites
KcDavis My Ride Posted April 1, 2010 The pre mix is the engine oil. You don't put engine oil in anywhere. It is not a 4 stroke. That is why you mix the gas. There should be a number stamped on the clutch side. That is how much tranny fluid you put in. Get a manual ASAP! Share this post Link to post Share on other sites
2strk Posted April 1, 2010 lol i have a yz250f so thats why im wondsering!! lol so its just regular tranny oil in the cranckcase? and premix with gas right?? and whats a good tranny oil for the 2t? Share this post Link to post Share on other sites
2strk Posted April 1, 2010 and is like some regular 2t tranny oil good from autozone?? Share this post Link to post Share on other sites
MotoX178 My Ride Posted April 1, 2010 I just use Rotella in my transmission, cheap at Wal-Mart and works great. Share this post Link to post Share on other sites
2strk Posted April 1, 2010 I just use Rotella in my transmission, cheap at Wal-Mart and works great.any certain weight? Share this post Link to post Share on other sites
KcDavis My Ride Posted April 1, 2010 I use ATF Type F and it is only a couple bucks a bottle. But whatever you use in the tranny of your 250f would work just fine too. And definitely premix in the gas... ha ha Right now, I am using Maxima Super M, but once that is gone I want to try Amsoil. Share this post Link to post Share on other sites
2strk Posted April 1, 2010 I use ATF Type F and it is only a couple bucks a bottle. But whatever you use in the tranny of your 250f would work just fine too. And definitely premix in the gas... ha ha Right now, I am using Maxima Super M, but once that is gone I want to try Amsoil. so can i run gtx 2t oil? from auto zone? Share this post Link to post Share on other sites
Clear-Rad Posted April 1, 2010 Yes get an owners manual. Your 2-stroke doesnt have engine/motor oil. The only oil you need is transmission/gear oil and 2-stroke oil to mix in your gas. I prefer honda oils. Gear oil You fill this into your casing untill it purges out the "full" screw hole. 2-Stroke oil for your gas Honda recommends 32:1 ratio. So, start at 32:1 then adjust to your preference from there. Also, get a new avatar for the CR-125. LOL Share this post Link to post Share on other sites
2strk Posted April 1, 2010 lol thnaks man yall have been a great help!!!!!! and yeah ill get to it asap! Share this post Link to post Share on other sites
