Red Coolant
I going to do the loctite fix today. And I got some red coolant (G30) for my car.
Which is made for aluminum engines, and since the DRZ engine is mostly aluminum i was wondering if it OK to use it?
And how much coolant am I supposed to fill up?
I flushed my radiator and replaced the coolant last June. It was also red. From memory it was Toyota coolant.
According to the instructions it required a 50/50 mix with water (I used distilled water). Bear in mind that where I live it is unlikely to ever get below freezing point.
It was actually the local Suzuki dealer that told me to use that brand.
No issues so far.
Edited by Rideforyourlife
Additional info
I filled my rads yesterday. I decided to try Bronco's method of bleeding. You just fill and cap, then tip the bike to both sides (almost laying down), top-off again, repeat. It was done after three cycles. It's a little aerobic but less mess and more surefire.
├Ś
├Ś
