iDuner Posted April 1, 2010 Is there a way i can put a semi auto clutch in a manual clutch engine? thanks Share this post Link to post Share on other sites
iDuner Posted April 4, 2010 Does anyone know if i could swap a manual for automatic clutch thanks. Share this post Link to post Share on other sites
scooterpimp Posted April 4, 2010 Seen Kits To Go From Semi Auto To Manual , But Havent Seen Snything That Goes The Other Way? Depending On Engine. It May Be Cheaper To Get A Semi Auto Engine & Do A Swap.Verses Tracking Down The Parts Needed To Do Conversion. Share this post Link to post Share on other sites
dirtbkr188 Posted April 4, 2010 If you have a crank mounted clutch, it is possible to swap out the manual for the semi-auto setup, as long as you have all the parts needed to replace the manual setup. Post some pictures of your engine, to see if it can be done. Share this post Link to post Share on other sites
